Red dash light on a TO-20...meaning
zippy4554
06-20-2005 07:16:39
The red light means the system is not charging. This could be for any of a number of reasons, engine running too slow, regulator not working, generator not providing a charge etc.
In your case with 12V, there may be other reasons. If it is now negative ground, I suspect the red light will be on all the time. I guess you'd need an ammeter hooked up properly to see what was going on.
Kiwi
02-04-2006 18:38:10
 Re: Red dash light on a TO-20...meaning in reply to zippy4554, 06-20-2005 07:16:39
I need to replace the bulb in the Dash Light of my TEA-20.(12v system)
Can anybody out there give the correct spec. for this bulb,ie. voltage, wattage and fitting type, etc.
Thank you in anticipation,
Ray
