Re: PTO slips?
Jeff-oh
09-18-2006 11:36:15
I agree with Steve. Most likely you did not have the PTO Fully engaged. I would not worry.
The PTO on the TO-30 does not have "ground"-PTO. That feature was not available until the TO-35. There is no PTO clutch. So there is nothing to slip. The PTO on a TO-30 is direct driven on the transmission shaft. It is either on or not.
The lever on the side has a short lever on the inside that rides in a grove on the PTO gear. When moved it slides the PTO Gear aft to mesh with a gear on the Engine power shaft going to the transmission.
Most likely the gear lined up tooth to tooth and it the lever felt like it was engaged, or as steve said it was not fully engages and slipped out.
Relax, don"t worry, go mowing. If this becomes a cronic problem then write back on it.
