Forgot to mention
John (TR)
03-30-2007 16:22:43
The crank did not have to be ground again, they polished it instead. After hearing of my oil pressure problem the Machine shop asked for the rods and took a little off the caps and re-borred the rods so they are perfect ID for the bearings. This is much the same way the fix the caps when line boring the block.
Indiana Jones
03-31-2007 06:03:08
 Re: Forgot to mention in reply to John (TR), 03-30-2007 16:22:43
Nice pics. Question: Is the piston height from pin to top the same for 3-ring and 4-ring pistons or is the 4-ring piston taller?
Dean
04-01-2007 05:02:11
 Re: Forgot to mention in reply to Indiana Jones, 03-31-2007 06:03:08
Indiana:
The piston height should be the same for 4 ring pistons as three ring pistons. The fourth ring is an additional oil control ring on the piston skirt below the wrist pin.
The last time I looked I could only find flat topped 4 ring pistons. The three ring pistons are available either flat topped or slightly domed. The domed pistons increase power noticably.
Dean
John (TR)
03-31-2007 19:56:34
I don't know myself
