Steering Shaft Bearings.
Bob (Aust)
03-02-2008 20:33:42
Randy. You have two identical bearings, top and bottom of the steering shaft.
third party image
The top bearing does not get lubricant and usually fails first, the bottom bearing is not exposed to water to the same extent and gets some lubrication from the steering box.
I think that Timken number may be correct. It is a three piece bearing (part numbered "6" in the diagram above), cup, cone and cage. Buy a new bearing, pack and give it a good coating of grease, install and adjust the top lock nut for load.
I think that will fix your problem.
If you can verify the Timken (or other brand) part number, post here as there have been a number of queries on the forum for details on that bearing which I don't think is available from Ferguson or MF dealers.
