Order Ford 4000 Parts Online
Re: Re: Re: Re: Power steering problem on 4000
bfid
10-08-2000 13:14:07
Your right it is a 70 model 3 cyclinder I'm sure it has some wear in it cause when I bought the tractor it was dry in the reservior and I think my only permanent fix would be to replace it but for now what type of fluid could I use to help out that wouldn't thin down as much?
Thanks alot for your help Bern.I appreciate it.
Bern
10-08-2000 15:01:19
 Re: Re: Re: Re: Re: Power steering problem on 4000 in reply to bfid, 10-08-2000 13:14:07
Since the pump needs to be replaced anyway, maybe you could try a heavier weight engine oil, say 50 wt? That might help some, I doubt you'd hurt anything by doing that. I wouldn't go so far as to use 90wt gear oil though, I think that would be pushing it. This is just my opinion, I have not tried either way. Maybe someone else can share any of their experiences in this area.
