Order Ford NAA Parts Online
Re: NAA
pete L
04-10-2004 14:46:37
The NAA is a valve-in-head engine, and you may have valves that have dried up and are not moving. Suggest pulling the valve cover, cranking the engine, and seeing if the valves and push rods are moving. If not, soak with penetrating oil for several days and gently tap with a hammer on top of the valve. Hopefully you won't have to immediately pull the head. Good luck.
