rings for cylinder
Beststash
01-14-2005 13:00:13
Everything is apart....I checked the cam follower pin it is OK. I have the piston out and it only has an o-ring, no backup leather which my manual calls for - Manual calls for installing leather with rough side toward closed end of piston - does the o-ring go behind the leather (toward open end of piston)?? Also, I got a lift rebuild kit for 2000, 3000, and 4000 - it has three different size o-rings, a leather, and also a split plastic looking ring. One of the o-rings seems to be right size and also the leather (if I can stretch it that far)should I use these or just go to NH and get another kit (will it be the same??)
The piston does have a few wear marks but seems to be OK, it or the wall is not scored but appears to be wear?
Can you help??
