Order Ford 601 Parts Online
Re: 601 Plugs fouling
mowr
06-22-2005 15:31:14
An RH18Y is a much hotter plug than an H10, and fouling the 18's means way too much fuel or oil in the cylinders. Engines sometimes have good compression and bad oil rings or vice versa.
souNdguy
06-23-2005 06:01:02
 Re: 601 Plugs fouling in reply to mowr, 06-22-2005 15:31:14
Is that plug a resistor plug? ( I would not use resitor plugs or wires.. )
I'd use AL-437's ( champ H-12 ). Also.. He needs to use metal core wires.. not carbon supressor wires.
Soundguy
john in la
06-22-2005 16:05:36
This is only a guess because we do not know if it is oil or gas fouled..... ..... But..... ....
If it is oil fouled I would guess valve guide bushings.
The valve closes tight so compression is good but when the valve opens the oil runs in the cylinder.
shoe
06-22-2005 20:36:18
 Re: 601 Plugs fouling in reply to john in la, 06-22-2005 16:05:36
Sounds like to me you got an oil burner, either valve guides or rings, time for an overhaul.
