Order Ford 971 Parts Online
Are you sure it's not a 971?
awhtx
01-31-2006 18:43:10
That number you posted- 310608 - are you sure it's not 310609? The 172 diesel engine has 310609 cast into the right side of the block. I don't know what number the 144 diesel block has.
ford-s
02-01-2006 06:56:50
 Re: Are you sure it's not a 971? in reply to awhtx, 01-31-2006 18:43:10
awhtx,at closer inspection it is a 971,thanks.Is the engine the only thing that varies between a971 and a 771? cw
awhtx
02-01-2006 07:43:09
 Re: Are you sure it's not a 971? in reply to ford-s, 02-01-2006 06:56:50
The rear axle on an 800/801 is larger than the rear axle on a 600/601. I would assume the same applies to the 700/701 and 900/901 but I'm not sure. Maybe one of the experts will help you on that.
The engines (134G,144D,172G,172D) all have the same bolt pattern where the engine bolts to the transmission so it is also possible that you have a 771 with the larger 172D engine.
