Start at fuel tank
bjr
04-06-2006 10:18:20
I would start with line coming from tank. Do what it takes to get fuel there. blow thru backwards to fuel tank (make sure valve is on) with low pressure air 20-30 psi. Then bleed fuel filter, then pump (no air pressure on fuel pump or filter though) and should be able to get engine to smoke white while cranking and that indicates it's getting fuel and then it should start. bjr
