Crankcase pressure?
bjr
04-28-2006 06:36:53
It's an interesting subject. What's the opinion of you guys out there? Is Positve pressure better, as in keeping dust out, but having a few oil leaks as result. The other, negative crank case pressure, but fewer oil leaks, but maybe ingesting dust? Is measuring with a manometer good way to guage what is going on with the crankcase pressures? If so, what kind of readings should a person see? I'm wondering if there is optional sizes,orifices, of PVC valves to change crankcase pressures? I'm sure this has been discussed before, but a current consensus might bear valuable information. bjr
gerard
04-28-2006 13:43:36
 Re: Crankcase pressure? in reply to bjr, 04-28-2006 06:36:53
negative crankcase pressure prevents oil leaks and raises power output. Dust should not get in, as crankcases that generate negative pressure normally have a filter for incoming air.
