Original fuel tanks are soldered together
awhtx
12-28-2006 13:51:27
The upper and lower halves of the Ford tanks are soldered together. If you weld up any cracks that occur where the mounting brackets are spot welded to the tank you need to watch the heat so that you don't melt the solder.
Wayne in Iowa
12-28-2006 16:55:54
 Re: Original fuel tanks are soldered together in reply to awhtx, 12-28-2006 13:51:27
Toward the front of the tank is a mounting bracket spot welded to the tank. I electric welded this bracket, full lenth, front and rear. to the tank. Then I used a product called Pour 15 Used as directed on the can. It's been four years , so far so good . Actually I did it on 2 tractors (860 & 960) HTH
