If you have moved the tractor with ...
awhtx
02-26-2007 19:13:40
the engine not running and the rear wheels turned then your disconnect lever that bjr mentioned is in the "freewheeling" position. With no hydraulic pressure present the SOS goes into Park. If the engine is not running there is no hydraulic pressure in the SOS and the rear wheels are locked.
