Carb spacer
awhtx
04-26-2007 10:11:01
It should be as simple to make as finding a piece of aluminum plate of the proper thickness and then use a carburetor to manifold gasket to lay out the pattern. To cut the large hole in the center drill a bunch of small holes around the diameter and then use a saber saw to cut between them.
