Torque limit clutch?
bjr
05-14-2007 13:42:40
My old 4000D (like a 871)had a busted torque limit clucth plate. Actually it stripped out the rivets on the hub. This is like a small clutch that goes on the flywheel so you would have to split the tractor to fix it. When I was looking for a good used one, as I couldn't get new. I found out there were different splines. So if you have this problem just count splines and measure the diameter. I found one from Draper Tractor in WA. state. Cost $130,I think. bjr
