Loops
bjr
05-25-2007 08:22:32
You make a good point. Are there replacement loops available? And is there a good method of installing, welding, the loops on the blank? I've priced wheels locally, Eastern WA. and they're astrinomical. I would like to get blanks a make my own. The same size as what the poster needed. bjr
RodInNS
05-25-2007 09:08:52
 Re: Loops in reply to bjr, 05-25-2007 08:22:32
Yes, you can buy the loops too. They're a few bucks a piece from the same gang that sells the wheels. As to installing them.... I would set the wheel on it's bead on something smooth and flat like a big steel table or somethign of that nature. Then get the dish set up in place in the wheel and fit them up and weld them in. You would need to improvise some sort of jig like that anyway. Let the imagination run wild....
Rod
