Order Ford 4000 Parts Online
I've had early 4000 SOS about 1 yr
bjr
07-31-2007 06:45:33
The old tractor I traded for has the SOS (Selecto-Speed). Mine had the torque limiting clutch out when I got it. Once I got it up and running I just love it for the slow 1st gear for tilling and the hydraulic clutch PTO is great to be able to not have grind gear to engage it. I think the shifting operating cables parts are difficult to find though. I'm considering a foot throttle conversion though, but, everything else about the tractor is fine. bjr
souNdguy
07-31-2007 11:31:30
 Re: I've had early 4000 SOS about 1 yr in reply to bjr, 07-31-2007 06:45:33
Even on a single or 2 stage clutch machine.. if you werere grinding gears to engage it.. you were doing something wrong.. or it was out of adjustment. A properly functioning dry clutch system should engage just as easy as a hyd engage... just pull a lever ( or cable ) and go...
Soundguy
