223 cu.in. 6 cylinder- is it a car engine?
awhtx
08-03-2007 20:02:42
I think I read somewhere that the 223 used in the 6000 was actually a car engine. Does anyone know if this is true?
Bob N.Y.
08-07-2007 16:45:53
 Re: 223 cu.in. 6 cylinder- is it a car engine? in reply to awhtx, 08-03-2007 20:02:42
I am reasonably sure that the 6000 engine was based on the medium duty truck engine and is slightly different than the car engine. The diesel uses larger bolts for the main bearing caps.
PatsPOS
08-03-2007 20:14:40
Not sure yet...my dad has a '56 Ford Mainliner with a 223. If I can ever get the dang hood open, I'll confirm or deny this!
I'd like to find out myself...I'm thinking IF the 223 car and 223 tractor engine were the same blocks, then a 223 car engine MIGHT fit into a x00, x01, or a pre-'65 x000 tractor without TOO much work. I'm not a big fan of flatheads (too young, I reckon), but I think an OHV 6-cylinder on a little grey and red tractor would be pretty slick!
Pat
Fordfarmer
08-04-2007 06:53:13
 Re: 223 cu.in. 6 cylinder- is it a car engine? in reply to PatsPOS, 08-03-2007 20:14:40
Got to thinking about this while I was milking this morning. There were Funk 6-cylinder kits that used an 215 c.i. OHV industrial engine. The flathead 6's were 226 or 227 cubic inches, depending on where you get your infomation. The OHV industrials were introduced (I think) in '52. If by some chance the car block is the same as the 6000's, (more likely for a truck or industrial block to match) I'd think you'd need an adapter plate for the bellhousing, plus a taller and longer hood, some way of attaching the front axle, and probably some kind of frame rails to put one into a pre-65 4-cylinder. And a governor.
Fordfarmer
08-03-2007 20:27:12
I've heard that the 6000 gs engine was the same as a car engine too, but I doubt it. I do know that it WON'T bolt into an x00, x01, or 4-cylinder x000. The 6000 used a completly unique trans.
PatsPOS
08-04-2007 20:51:02
 Re: 223 cu.in. 6 cylinder- is it a car engine? in reply to Fordfarmer, 08-03-2007 20:27:12
Fordfarmer...I'm sure not trying to start an argument, but are you sure? I've looked pretty hard at the SOS trannies in both our '63 4000 and our '63 6000. Other than the fact that the 6000 has an external tranny filter, they look virtually identical. Bellhousing bolt pattern looks to be the same between the two tractors, which is where I came up with the nutty idea of a 6-cylinder swap in the first place.
You're probably right about the front needing reinforcement, even if everything else were to work out.
Pat
