Conduit for PTO cable on SOS
NWMO 901 SOS
08-14-2007 05:49:21
Hey all,
The PTO feathering cable conduit on my tractor has some inner damage that doesn't allow the cable to operate smoothly. Ford has the new part (#312454) but I believe I should be able to put something together for significantly less than $60+. My cable appears to be in good shape, the current conduit appears to be brass? I know the 22.34" length is crucial, is there something I can use, possibly brake line or some other tubing to replace this conduit?
TIA Chris
Kerry Hayes
10-13-2007 17:39:03
 Re: Conduit for PTO cable on SOS in reply to NWMO 901 SOS, 08-14-2007 05:49:21
Hey would you have any connection on a shifter cable for a ford 5000 with the SOS tran.? Just broke mind and not sure where to find one.
Thanks Kerry Hayes
Dean
08-14-2007 14:47:10
Chris:
You should snap up that conduit while you have the chance. Some S-O-S PTO cable conduits are much much more expensive than $60 and others are no longer available.
Dean
hurleyjd
08-14-2007 06:37:15
For goodness sake, pay the $60.00 and get on with life. I have tried doing the same thing at times. Usually end up scrapping the thing I was trying to make and buying the part that was needed.
NWMO 901 SOS
08-14-2007 06:46:34
 Re: Conduit for PTO cable on SOS in reply to hurleyjd, 08-14-2007 06:37:15
Hurley,
Thank you for the reply. I'm just getting started with this tractor and could easily have 9 more similar difficulties. That turns into hundreds of dollars. I just got a 1/4" brass tube and nuts. It has a little thinner wall, but if I can flare the ends at all and it bends ok (not a lot needed) I will have saved over $50 and not had to wait on CNH. I'll let you know how it goes.
Chris
hurleyjd
08-14-2007 12:03:28
 Re: Conduit for PTO cable on SOS in reply to NWMO 901 SOS, 08-14-2007 06:46:34
The tube on my SOS is cad plated steel. Looks like brass. Brass will wear out pretty fast.
NWMO 901 SOS
08-14-2007 12:21:03
 Re: Conduit for PTO cable on SOS in reply to hurleyjd, 08-14-2007 12:03:28
Hurley,
Thanks for the info. The brass tube I got is relatively thin and I can see heavy use causing wear. I'm only going to use the tractor around the "hobby" farm and don't expect to use the PTO more than 15-20 times a year. We'll see how it goes.
Chris
awhtx
08-14-2007 07:10:40
 Recent discussion of the same subject in reply to NWMO 901 SOS, 08-14-2007 06:46:34
Here is the same question.
