Are the Model and Serial numbers still legible....
awhtx
09-16-2007 19:57:55
on your tractor? The diesels came with a 12 volt, negative ground electrical system from the factory. The battery would leak acid and it dripped onto the area of the transmission where the model and serial numbers were stamped eating them away.
One more thing- the early SOS's had problems and they were recalled. The dealer would install a factory updated transmission and they were supposed to restamp the original model and serial number of the tractor onto the replacement transmission. Do you know if yours has been restamped if it's legible at all?
