3 point lift
awhtx
10-25-2007 15:53:46
The problem with your 3 point lift is a common sign of a worn cam follower pin. Search the archives of this site for "cam follower pin" and you will find a large amount of information. You must remove the lift cover from your tractor to replace the cam follower pin and you can adjust the linkage while you're in there. I'm sure you will find reference to a cam follower pin replacement kit sold by ZANE when you search the archives.
