Note to RodinNS:
awhtx
12-12-2007 09:21:48
Rod- you always provide lots of good information but you're incorrect this time. The dual stage clutch assembly (as used in the X61 and pre 65 4000) bolts to the flywheel around the outer circumference just like a single stage but the clutch disk DOES NOT contact the flywheel. The disks and pressure plates are all contained within the clutch assembly.
RodInNS
12-12-2007 18:22:07
 Re: Note to RodinNS: in reply to awhtx, 12-12-2007 09:21:48
Ok...
It's certainly the first one I've ever heard of like that. Also explains why they're so prone to sticking, and certainly why they're so expensive to repair too...
Rod
