Attn: RickB PTO Brake Question
awhtx
02-27-2008 17:34:29
RickB,
I have a 1967 5000 with SOS which should have the brake pad on the end of a pawl. Can I install the later system which uses a brake band? I understand that it provides a lot more braking surface than the original pawl.
RickB
02-28-2008 15:55:16
 Interesting question in reply to awhtx, 02-27-2008 17:34:29
At a minimum the complete valve housing and support would have to be changed. There was no change in the clutch drum itself, so that's a good thing. Looks like the late valve has only one locating screw through the rear end housing. No idea whether the drilling is in the same location as one of the two similar holes in the early rear axle housing. Control valve linkage is different as well. Probably not worth the aggrivation.
norsky 63
02-29-2008 15:08:28
 Re: Interesting question in reply to RickB, 02-28-2008 15:55:16
I have a 65 5000 and had the same problem. Jack up the left side of tractor so oil doesn't run out. Then remove the left foot rest and small inspection plate. Inside you can see where the pto lever pushes on a small hyd. valve. that little button should pop out all the eay when you put the lever in the disengage posistion. On mine it only came out 1/2 " I got in there with a screwdriver and twisted and bam! it popped out about another inch and problem solved. This not sos tractor. The pto now stops but not completely if i push just a lil with a board it stops. It wouldn't turn a load.
