Check pump timing
bjr
03-03-2008 09:28:58
I"ve sworn that I had my pump in correctly and guess what, I was 180 degrees out of time. That engine will run if pump is timed correctly. The tab is offset on the bottom of pump drive, so be aware if pump won"t seat properly. The pump drive gear is like a Ford distributor drive in that it"s easy to be off a tooth or more. Double check or like me I quadruple checked before I finally got it right. bjr
