Fordson Tractors Discussion Forum
I have a Dexta power steering kit
WayneB
12-10-2005 14:45:09
I bought a Dexta PS kit for mine, when I had a Wagner WF3 loader on it. Kit could not be mounted, because the left steering arm hit the loader. When I removed the loader, I could steer the tractor with one finger. Did not need it.
I'm likely going to put the kit on my Super Dexta. I'm putting my loader on my big Ford.
The kit I have uses only the left steering arm with a cross tie rod up front. Everything fits well, uses a longer belt and the pump mounts on the left side. Neat kit, looks good, but it would require a Freeman loader or one of the quick removal type loaders. The old step in type Wagner, Superior and other varieties, with the support beam even or just above the front axle level will hit the steering tie rod.
Sort thru finding a loader that will not interfeere with steering before you buy your kit.
Wayne
