Re: Re: Boring 10 hp to 12 hp Kohler
Wally G.
05-15-2003 17:19:19
You should probably sleeve it back to Std. because by the time you get the 12 or 14 crankshaft then the new connecting rod, and you can use the 10HP head on a 12 or 14 horsepower, you will be running into a lot more money. If you use the 10HP crank and the 12HP piston and rod the piston will be about a 1/4" below the deck of the block making less compression.
