Re: Ariens Rocket Tiller Model 901003
lucas
03-20-2004 08:54:23
that rocket is the same as mine and came with tecumseh hh70 7hp engine. tecumseh supplies an 8 hp for it now as the 7hp hasnt been made for quite some time ,most tecumseh dealers know the airens engine replacement. you only need the aux pto if you want reverse on the wheels,otherwise one pto will work everything else.i have put some 5hp biggs on rockets and seem to work ok except for breaking hard virgin soil.i also have parts and service manuals and airens still has parts for the tiller... you may want to change the two gearbox oils with 90w and watch for leaks as you use it.mine is a 1978 and ive put a couple seals in the tine shaft a few years ago,but its not hard to do.you have to rock the wheels to get the wheels in high or low but to engage the tines just flip the lever forward and it drops into gear when the belts tighten.great tiller...lucas
