Re: Backfires when hot
JT
08-01-2004 13:55:24
Have you checked the spark when it dies or after it cools off. A quick way to find out if it the igntion is to unplug the kill wire in the hearness where the tractor and engine wires plug to each other. Usually it is a white wire, then go run it, if it still dies then you know it is in the egnine and not the tractor. This thing has 2 coils on it if it is a V twin, so you have to eliminate the safety system, becasue it sounds like you mighht be loosing ignition to me. If it has a SAM unit on it, that could be going bad also. If you get your engine model go to www.kohler.com and you can download a manual for this engine.
