Answer
stronics
11-22-2004 18:02:38
For whatever reason it is not getting gas, simple as that. Start with:
Clean the junk out of the fuel tank. Take off and flush.
Blow out the lines good, new fuel filter if it has one, check at the carb if it's getting fuel.
Then take the carb completely apart, everything, and boil it out good with a soaking carb cleaner for at least two hours. Rinse good with water and blow out all orfices (everyone). Now replace the needle vlave, and set the float height. Replace the idle adjustment and the high speed adjustment turned out 1 1/2 turns or so. Don't forget the new gaskets.
Start and adjust mixtures.
Thats it.
David
