no it not
vjd
04-11-2006 18:50:22
the fly key is not bent, I now have the engin opened up cant see any thing wrong in side
rustyj14
04-12-2006 17:50:28
 Re: no it not in reply to vjd , 04-11-2006 18:50:22
Flywheel key does not bend--it shears off. Caused by a backfire, loose flywheel nut, sudden stop of engine rotation due to broken connecting rod! On a rotary lawn mower, hitting the water or gas curb box, or a pipe hidden by weeds or long grass, which stops the engine quickly, will definitely shear the flywheel key! Note: when you put the engine back together again, pay strict attention to the timing marks on cam and crankshaft gears, and also to getting the governor in correctly! Its a bit tricky getting it all back in where its supposed to go!
