Re: Eight acres of Salad
tim[in]
06-28-2003 17:10:01
you might adjust rollers to squeeze a little tighter. some also go behind with an old fashioned hay conditioner and crush it again. also cut a little higher so as to leave stubble for the hay to rest on and the wind to pass underneath. i try to leave the windrow wide enough so there is just enough bare space for the cutter shoe not to run on cut hay from previous swath. so the windrow is as wide as possible. also cut as close to noon but not after if at all possible when cutting. this is like adding another drying day to the hay.
