Re: John Deere 420 Two Row Utility
MIKE HANLEY
03-19-2003 06:34:43
My 1958 book that introduced the slant sheering wheel on the 420 lists the Utility on the same page with the 320 and says excellent for grove vineyard and orchard.
It then lists on the next page the Row-crop utility that can have the front wheels spaced up to 80" (88" optional) and the rear wheels spaced up to 98". 21" crop claerance. This husky tractor plants and culivates 2 or 4 rows with extra stability you want for working on sloping fields.
The parts book shoW a tube front axel for the utility (U serial number) and a square axel for the row crop utility (W serial number) and then it showes a square axel for the special utility (V serial number). The tect manual lists the special between the utility and the row crop utility and is really an "inbetween" between the row crop and the hi-crop. I can not find anything that lists or shows a tractor with a U serial serail number with a square front axel.
MIKE HANLEY
03-19-2003 10:58:34
 Re: Re: John Deere 420 Two Row Utility in reply to MIKE HANLEY, 03-19-2003 06:34:43
After thought. What are the dementions of your tractor? Could it be that at some point in time someone changed out the casting with the serial number from a W to U and left on the U serial #. Might be worth it to send the serial # to 2 cylinder and see what they say. Maybe you dom have something special.
