Re: JD MC
CPeter
05-04-2005 05:29:24
As with any crawler, there are many variables. The under carriage is the most important thing to look at. The MC uses a different system to mount the rolls than the later machines and this can be a problem. If you are going to use the machine, it is a real short track and tends to be nose heavy if you put too much blade on it. The past life would be important to know. Here in New Hampshire, beating around the granite filled woods was hard on them. A machine that was used in nice soft ground would not have the same breakage problems as one from here would have.
Price**anywhere from $500 and up depending on condition.
CPeter
