Re: Won't start
Bob
11-11-1999 22:11:53
Are you sure your glow plugs are working? Check with a test light to see if there is power going to them. If there is than pull them out and hook them to a battery with a set of jumper cables to see if they get hot. My guess is they are all 3 burned out. you probably have been running on one or two and the last one has finially given up
DeerePuller
11-12-1999 09:05:28
 Re: Re: Won't start in reply to Bob, 11-11-1999 22:11:53
On the JD 4000's there is a fuse that will blow out on the lefthand side inside the counsil. I don't Know if your 2510 has that but our problem was that the tractor would not start or turn over until we put a new fuse or a piece of wire in there.
