F I T
41JDb
02-28-2006 14:00:46
Alright thanks for the great picture. So those bolts dont need to be removed? Wonder if it would help? Thanks a lot Al
F-I-T
02-28-2006 14:31:30
 Re: F I T in reply to 41JDb, 02-28-2006 14:00:46
Well, you can loosen the outside ones, or remove them and the ratchet hub, but I'm not sure it will really help. It does remove some of the mass if you have to remove the flywheel. I think if you can get the back side bolts loosened, then move the flywheel, then re-torque them you should be all right.
Frank
