Re: 3010D PTO clutch
msb
09-17-2006 19:27:09
Can you feel any resistence in the PTO lever when you engage the clutch?Sounds like the adjusting bolt locks were not locked down tight.Even with some oil on the clutch there should be enough pressure on the clutch to run a baler unless it is a big baler,round or otherwise.
Jim Glidewell
10-03-2006 18:21:44
 Re: 3010D PTO clutch in reply to msb, 09-17-2006 19:27:09
No, there is little to no resistance when the lever is engaged. Not knowing much about this, can the locks be tightened through the clutch inspection opening? I appreciate your help. Jim
