scooter01922
12-23-2007 10:59:41
It does indeed have 2 ports on that side of the pump, it doesn't really make sense to me either. Pressure readings taken at the forward and reverse test ports on top of the reverser indicate 0 regardless of rpm. The reverser supply test port (the one on the back of it) is unfortunately inaccessible without removing a hyd line that goes from the "reverser charge pressure” line to the hyd filter. and that would really defeat the purpose as I couldn’t start it with the line off. After pulling that plug partially and starting the tractor I can tell you there certainly isn't 100 PSI there with it running anyway. I'm at the second job now, so all tinkering will have to wait till tomorrow. Good to see I’m not the only one stumped on how the hydraulics still work.
