Re: John Deere 310C water problem
restingrelics1
03-10-2008 13:42:29
Jim, I think you've got a problem with compression getting into the cooling system. Usually a head gasket but you could have a cavatated sleeve or worse a crack somewhere in the head or block. Try running with the raditor cap loose. If after a short while it blows out the coolant you can start the tear down. If it takes a while it could be a cooling problem but that should just boil over not blow the hoses off.
Jim 72
03-11-2008 10:25:34
 Re: John Deere 310C water problem in reply to restingrelics1, 03-10-2008 13:42:29
I will give the open cap a try. I am prepared to get into the head gasket issue. Hopefully that will be it if I have to go deeper. If you think of anything else let me know. I am going to give it a try in the next day of two and will let you know. Thanks
Jim 72
03-18-2008 07:02:16
 Re: John Deere 310C water problem in reply to Jim 72, 03-11-2008 10:25:34
I wanted to let you know that when we got the head off there was an obvious gasket leak that had been there for a long time. The head is a little pitted around the valve and had been bleeding over to another cylinder a little. It looks as if the gasket will seal everything back off and we put it back together. I want to get some things changed before I fire it up but am hopeful that we have the problem fixed. Thanks for the info.
