Re: Fywheel wrench for G
JD70Jim
10-26-2002 06:35:06
The reason you cannot get ahold of Shorty, is that he has passed away.
As for the wrench, you are looking for a B 353 R wrench, and they are common at places where the parts vendors go, like shows. A good one should run from $20-30 I suppose. Lots of estate farm auctions tend to have them also. It is a big, double ended box wrench, with the size fitting the flywheel on one end and the size for the wheel clamps on the other.
I know they are very common, I have three of them.
Mike 3
10-26-2002 07:09:16
 Re: Re: Fywheel wrench for G in reply to JD70Jim, 10-26-2002 06:35:06
The B353R wrench won't do a lot of good on a G with out a D2064R wrench which is bent to get behind the flywheel.The b353R can be used to turn the D2064R. the 3/4" drive extention bent to fit works well.
DMoos
10-28-2002 13:47:51
 Re: Re: Re: Fywheel wrench for G in reply to Mike 3, 10-26-2002 07:09:16
Can someone send me a picture of a bent 3/4 extension.
Thanks
