Re: 47A block to Crank case torque spec.
Morgan
11-14-2002 18:31:16
Well Jim, I guess we'll just have to use the "one
grunt-2 grunt" method. No not really! I think I read here some where that it was 167 lbs. but I am not sure, Maybe some body will jump in and tell us for sure. morgan
Jim
11-15-2002 08:48:58
 Re: Re: 47A block to Crank case torque spec. in reply to Morgan, 11-14-2002 18:31:16
Morgan----- assuming that the head is torqued at 150.the block bolts should be about the same----.I am still searching for true J.D. specs.----Some where in my shop I have some older shop manuals that tell torque specs, for the bolt hardness and size of bolts,I think i'll have to hunt them down and see how close 150ft.lbs. will be.I do hope there is somebody out there that knows the actual torque spec. By the way,how did you make out on the block gasket?-----thanks jim
Morgan
11-16-2002 19:04:59
 Re: Re: Re: 47A block to Crank case torque spec. in reply to Jim, 11-15-2002 08:48:58
I had to iron the gasket because Deere stored the gasket set on it's edge and the block gasket had taken a curl , so I hope it works,it came out pretty flat after I iron it. morgan
