Re: Re: AD3.152 Knock
CH
01-07-2003 14:10:34
Checked for pressure in crankcase and didn't find any at all. Thinking of pulling the injectors and sending them for service. When I do I'll check compression. It's got to warm up a little first.
Any other ideas?
Hammer
01-10-2003 21:06:39
 Re: Re: Re: AD3.152 Knock in reply to CH, 01-07-2003 14:10:34
I have a MF-245 with similar conditions. I asked the same question in this forum several years ago when I was considering purchase. Was advised the best explanation was either fuel advance detonation due to an anti-gel additive or piston slap. I got the oil analyzed and saw no aluminum, so ruled out piston slap. There is no blow-by or positive crankcase pressure, so rings appear OK. Condition is definitely worse during winter cold weather starts, then goes away after warm-up.
My conclusion was harmless combustion knock. Has performed flawlessly for many hundreds of hours since. Hope this helps.
CH
01-11-2003 06:03:27
 Re: Re: Re: Re: AD3.152 Knock in reply to Hammer, 01-10-2003 21:06:39
I stopped by my Massey dealer yesterday to pick up a few little things. I told him about it and that I intended to pull the injectors and let them clean and repair them. He told me to try this conditioner that AGCO puts out that's supposed to clean them real well. He's an honest guy. I hope it works, 5 bucks beats 60.
richard
01-11-2003 14:15:49
 Re: Re: Re: Re: Re: AD3.152 Knock in reply to CH, 01-11-2003 06:03:27
Remove the Lucas Thermostart cold start aid from the inlet manifold if you have one,see if the knock dissapears-these are prone to leaking fuel into the inlet manifold and causing a knock.
