Re: MF135 Hydraulics Question
Joe Ferguson
11-13-2003 15:48:11
Hi Bill
My MF-135 has factory auxiliary hydraulic system
It consist of a pump mounted over the 3 point hyd pump (piggyback) in the transmission housing.
The oil lines connexions (pressure & return)
are on the left side cover which carry the PTO shifter. This system has is own control valves and
is completely independant of the 3 point lift system and may be operated simultaneously.
Some are confused between expression
romote hydraulic system which operates from the
3 PT pump and auxiliary hydraulic system which is
totaly independant and it's operation have no
effect on 3 pt system.
On my 135 the aux hyd pump is double the 2nd part
is for independant PTO and Multi-Power.
HTH
Joe Ferguson.
