Re: MF 255 Opinions on this model
BB
08-28-2004 11:21:15
I went and looked at the tractor and it is in pretty bad shape. Engine ran very well but pto would not stop turning, lift was very slow picking up a box scrape untill you gave it lots of throttle, none of the gages worked except the temp gage, The front grill was wire, but did have headligths still there. Tractor cranks up and runs very well and rest of sheet metal waS IN DECENT shape. The auxillary hydralics when you move the lever that works them fluid shoots out of the couplings. The tractor turns good to the right but is hard to steer to the left. The tires were in good shape. LOOKS LIKE A MONEY PIT, WHAT DO YOU GUYS THINK? What should I offer the guy for the tractor or should I leave this one alone. tach did not work but showed 2350 hours.
BB
justplainjim
08-28-2004 12:47:47
 Re: MF 255 Opinions on this model in reply to BB, 08-28-2004 11:21:15
I think the hours on the tach are meaningless. This tractor was used hard and not maintained so expect to put lots of money and time into it...and of course while it is torn down you will not have a tractor to use.
I would rate this as a 'parts' tractor...with the screwed up steering it's not even a good drawbar tractor.
Ask a couple of local tractor wreckers what they would pay. Salvage value is all it's worth.
