Re: Wheel Spacing Advice Needed
Charlie T
11-11-2004 09:06:12
Bill I personally do not like the rear tires wider than the bush hog. I prefer the bush hog to cut the width of the tractor. Adjust your rear tires out to apoint which is covered by the Bushhog, as you stated this is what you will be doing mostly. This will allow you to get close to the small trees you referenced. For the front tires run those out to line up with the rears so that the tractor is uniformed. Please note this may not be the ideal situation for very steep terrain. Just my opinion.
