Ammeter last thoughts
Bill Darte
04-05-2005 12:14:40
Will the resolution that I get on a 60-0-60 automotive ammeter be distinguishable?
My 135 has a Delco-Remy alternator with and integrated plug on the 'back' with F & S terminals and a single wire running from the F terminal to the external voltage regulator. Nothing runs from the other terminal (S?). I understand that this was to wire up a 'dash light'.
Should this S terminal be connected anywhere?
Thanks loads for the information and perspective.
bd
txgrn
04-06-2005 07:10:38
 Re: Ammeter last thoughts in reply to Bill Darte, 04-05-2005 12:14:40
Some regulators labeled this terminal "L" for lights.
Mark
Gerald J.
04-05-2005 14:32:53
The stator wire is an output to run an idiot light that is worse than useless compared to a voltmeter. The idiot light goes out when the alternator voltage gets almost high enough to charge, but a slipping (glazed) belt won't give it any power to charge. That cost me a car once.
The 135's loads like ignition and flashing rear light may move the 60 amp meter pointer half a pointer's width. Though if you have a good sized wire from the alternator, you might get more than 30 amps charging. Costs you 8 bucks or so to try the wrong sized meter and then to change.
Gerald J.
