massey model 204 what fluid do i use
cheifhowie
05-19-2005 09:07:26
for the front bucket and back hoe. I couldn't find any port to put fluids except on the support post for front bucket. I put in 2 quarts and check the dip stick under the seat and it rose some. The front seals on the bucket is also leaking a white coloured fluid. I also took a sample of new hydraulic oil and added water, shook oil mixed,after 10 minutes it became paste and rose to the top of the zip lock bay..
Texas Denny
05-20-2005 14:49:14
 Re: massey model 204 what fluid do i use in reply to cheifhowie, 05-19-2005 09:07:26
There apparently is water in your hydraulic fluid. I can't offer how this could happen. I don't know what loader you have. Some loaders use the frame to store hydraulic fluid - use a tubular frame as a reservoir for the hydraulic oil. This is not a good mixture for your system. I'd recommend changing it. I'm not sure of the Massey Fergusen recommended fluid. If the tractor is a Massey Harris, non detergent 30 weight works fine.
