Thanks Big Dean
Arthur from Tas
06-13-2005 17:53:01
Hi Dean
Read your reply the couple of days ago, I will look for a pair of those springs or some sort of a substitute and give that a try.
with all new parts the nut on the adjusting rod is in about half of its length, so it looks like the wear inside the housings is the problem.
I will also investigate the fitting of oversized ballbearings in between the actuator plates
Many thanks for the information and all the best of luck for your new verture with your son.
Cheers Arthur from Tassy
