Make that a MH 20
Alberta Mike
09-29-2005 19:59:08
That should read MH20 (not 22).
Harris Guy
09-30-2005 10:22:54
 Re: Make that a MH 20 in reply to Alberta Mike, 09-29-2005 19:59:08
Mike,
Being '47 vintage, the engines are black, as
would be the breather tube,cap. The Radiator
shroud will be more your choice, but the bell-
housing was/is red. The original lamps were black,
with the chrome lens clamp. The oil bath breather
body was usually black, but if black seems too
dominant on a smaller tractor, try red. The
fan would be black, if you decide on black, for
the radiator shroud. With a red shroud, either
color fan blends well. Good luck, Pal.
Alberta Mike
09-30-2005 12:18:16
 Re: Make that a MH 20 in reply to Harris Guy, 09-30-2005 10:22:54
Thanks MY, I'll keep that info on file here. Don't know why I got into another tractor, I've got so many things to do I feel like a one-armed paper hanger. Oh well, it's only money. I'll email you a photo of it when I get one on my computer. I guess if a guy's gonna do something it might as well be MH, nothing easier or simpler to work on from my point of view. Can getting off those rear cast inner wheels be a challenge?
DCM
09-30-2005 16:32:45
 Re: Make that a MH 20 in reply to Alberta Mike, 09-30-2005 12:18:16
Howdy fellas,wasn"t "47 an anniversary year where MH engines were black or do I have my info wrong.Dan in AB
Alberta Mike
10-01-2005 06:47:41
 Re: Make that a MH 20 in reply to DCM, 09-30-2005 16:32:45
I think you might be right because I think I remember that in 1997 Massey had their 150th anniversary so 1947 would've been 100. I was only one yer old and am still 99 years behind.
Harris Guy
10-01-2005 11:25:35
 Re: Make that a MH 20 in reply to Alberta Mike, 10-01-2005 06:47:41
Yes, 1947 was the 100th Anniversary, so all engines were suppose to be black. However, if you
look back, 101 Seniors had black engines in '45,
or any years. Question remains, how many red engines in 1946? Who was counting? Accurate records of detail, were apparently not kept.
Alberta Mike
10-01-2005 12:59:50
 Re: Make that a MH 20 in reply to Harris Guy, 10-01-2005 11:25:35
A reference that I have here says that just one standard front tractor (s/n 1001) was produced in '46, that's a bit hard to believe.
