255 MFSteering
Big Dean
06-01-2007 10:33:45
If the shaft is not dropped down out of the casting or the flat plate on the bottom has not broke the weld. Then the arm David P has told you about behind the grille has probably cracked. The original arm that came on them from the factory was made to just slide over the shaft and did not fit really tight when the steering was over loaded it would crack. Those the replacement arm is split with a bolt to clamp it tight onto the shaft. If a picture of what I am talking about would help email.
