Re: Massey Ferguson 220-4
DavidP, South
06-05-2007 03:29:15
Hi,
I believe this tractor may be similar to the UK's 250 4WD. Does it have a 3 cylinder engine, spacer between the gearbox and rear casing, 8 speed transmission and oil immersed brakes?
If so, the tractor is basically good. Starting is not as good as the 135 for example due to the fact that the pump has been tweaked to give the extra 2 HP to help with the 4WD. I look after two working on a beach locally for launching boats.
The only problems of any consequence other than the normal things are fairly rapid wear in the front axle pivot pins and bushes, prop shaft wear and UJ wear in the axle hubs. Much of this may be due to the operating conditions. Look also for any signs of oil coming from the outer hub seals on the rear wheels. To replace these will require the use of a normally dealer only hydraulic puller.
Cheers
DavidP, SOuth Wales
Tom Chafin
06-05-2007 21:13:39
 Re: Massey Ferguson 220-4 in reply to DavidP, South Wales, 06-05-2007 03:29:15
Thanks for the information. See the reply I just posted and let me know if you forsee any problems.
Thank you very much
Tom
